configure iparp retransmit-time
configure iparp {retransmit-time retransmit_time}
Description
Sets the value for Address Resolution Protocol (ARP) retransmit time
Syntax Description
retransmit-time Specifies setting the retransmit time.
retransmit_time Sets the retransmit time value (range is 1–4,294,967 seconds or 1–4,294,967,295 milliseconds). Default is 1 second.
milliseconds When setting the retransmit time value, specifies milliseconds as the time unit (range is 1–4,294,967,295).
seconds When setting the retransmit time value, specifies seconds (range is 1–4,294,967) as the time unit (default).
Default
The default setting for the retransmit time is 1 second. The default unit of measure is seconds.
The following example sets the retransmit time to 500,000 seconds:
configure iparp retransmit-time 500000 seconds
This command was first available in ExtremeXOS 11.1.
Platform Availability
